Updated WLED and lost the feature I have relied upon. After developing patterns for an ESP32 devkit1 board, when I unplugged said board from PC or over the air, when I powered up board from 5v wall adapter I used to see my saved patterns display independently from being attached to my PC. Now I get all LEDS on with NO active patterns. Did the new update stop writing code directly to the chip? Am I not finding where the save button is other the the one at the bottom of the list?
Normal operation of WLED is to load the preset defined under “Apply at boot” (Config->LED Preferences).
If that isn’t set the default is to display all defined LEDs in orange.
Thank you very much. I believe that is the problem.
