ESp32 reebooting ~60 seconds
Hy @ all!
I installed WLed via the Webinstaller (and tried esptools later on as well, same result). Unfortunately it keeps rebooting approximately every 60 seconds.
I displayed the Log via the Webinstaller and this was the output:
Guru Meditation Error: Core 0 panic’ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x401584a4 PS : 0x00060e30 A0 : 0x80158e8a A1 : 0x3ffd6810
A2 : 0x00000000 A3 : 0x00000010 A4 : 0x0000012f A5 : 0x3ffd5874
A6 : 0x3ffdd80d A7 : 0x3ffdd93c A8 : 0x80157fbe A9 : 0x3ffd67f0
A10 : 0x00000001 A11 : 0x3ffdd80d A12 : 0x0000012f A13 : 0x00000001
A14 : 0x00060a23 A15 : 0x00000010 SAR : 0x00000010 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000004 LBEG : 0x4000c349 LEND : 0x4000c36b LCOUNT : 0x00000000
ELF file SHA256: 0000000000000000
Backtrace: 0x401584a1:0x3ffd6810 0x40158e87:0x3ffd6890 0x40158ee7:0x3ffd68c0 0x4008b546:0x3ffd68f0
Rebooting…
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DOUT, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
Ada
This is the device which I am using (I tried 3 of them, everytime the same result)
LEDs are connected on PIN 2 and 16
It happens regardeless if LEDs are connected to the Pins. Also no matter if on external Power /5v) or powerded via USB port.
Has anyone any idea, what causes this and how to resolve?
Thank you :slight_smile:
disconnect from GPIO2 and try it again.
Thank you for your answer.
I tried 2, 4, and 16. everytime the same :confused:
PC : 0x401584a4 PS : 0x00060a30 A0 : 0x80158e8a A1 : 0x3ffd6840
A2 : 0x00000000 A3 : 0x00000010 A4 : 0x000000cb A5 : 0x3ffd6de8
A6 : 0x3ffdd749 A7 : 0x3ffdd814 A8 : 0x80157fbe A9 : 0x3ffd6820
A10 : 0x00000001 A11 : 0x3ffdd749 A12 : 0x000000cb A13 : 0x00000001
A14 : 0x00060623 A15 : 0x00000010 SAR : 0x00000010 EXCCAUSE: 0x0000001c
Backtrace: 0x401584a1:0x3ffd6840 0x40158e87:0x3ffd68c0 0x40158ee7:0x3ffd68f0 0x4008b546:0x3ffd6920
Rebooting…
entry 0x400806a8
Ada
Disconnect all LEDs and try to run WLED, if it still rebooting without LED connected then your board is faulty.
Hy
All my 3 Boards had the same issue, so I bought another esp32 board from a different vendor:
No LEDs are connected, but this Board has the same issue as the previous ones:
PC : 0x401584a4 PS : 0x00060c30 A0 : 0x80158e8a A1 : 0x3ffd6550
A2 : 0x00000000 A3 : 0x00000010 A4 : 0x000000cb A5 : 0x3ffdbf98
A6 : 0x3ffdd7e9 A7 : 0x3ffdd8b4 A8 : 0x80157fbe A9 : 0x3ffd6530
A10 : 0x00000001 A11 : 0x3ffdd7e9 A12 : 0x000000cb A13 : 0x00000001
A14 : 0x00060823 A15 : 0x00000010 SAR : 0x00000010 EXCCAUSE: 0x0000001c
Backtrace: 0x401584a1:0x3ffd6550 0x40158e87:0x3ffd65d0 0x40158ee7:0x3ffd6600 0x4008b546:0x3ffd6630
Rebooting…
entry 0x400806a8
Ada
Definitely sounds like a Version/flash issue. I would suggest you try the Webinstaller with a different version of WLED. What version have you been using so far?
I used the WLED - Webinstaller version 0.13.1 so far.
Now I’m trying to install it via esptools. Should the error continue, i will try the webinstaller on another PC… Its really strange. If i install it on a wemos D1 mini, there is no problem at all…
I’ve had the best success with the webinstaller my self and I have a number of those WROOM-32 DEVKIT style boards. My guess would be a boot-loader/old memory crud issue. Might be worth forcing a full erase of board before loading.
Definitely try a different PC, I see someone has recently had success with a Linux box as well.
I suggest a different version (older/newer/beta) as you’re just trying to get something to load.
Once up, you can probably move to the version you want via OTA updates.
Normally this is a dirt simple process. :wink:
Thanks for your help. I did “esptool.py erase_flash” and tried to install via install.wled.me on another PC. Same result :confused:
Now I’ll try an old version
I think, I’m giving up… I tried WLED_0.10.2_ESP32_ledpin16.bin
Same issue…
Definition of insanity: Doing the same thing over and over and expecting different results :stuck_out_tongue_winking_eye:
We’re missing a variable somewhere…
You are right…
I think, i got the solution…
I digged into the settings, because the reboot happens exactly every 60 seconds…
So i did the following: Under Settings => Time & Macros => Time-controlled presets
there was by default every checkbox checked (Row En.)
I deseleced everything including sunrise and sunset, did a save and a reboot.
Now its up and running since 15 Minutes and 12 seconds.
In parallel, i tried it on a second ESP32 as well…
Up and runnung since 8 min and 18 seconds.
So there could be a bug, if under Time-controlled presets the checkboxes are checked, but Hour, Minute and Preset is 0-
The funny thing… I am the only one who encountered this? :astonished:
That’s part of why I suggested a full erase and then load an older version.
Loads try and save all your configs/presets/etc, makes life easier when you upgrade.
Unless you’ve got mush in your configs that cause an issue…
I did a full erase (“esptool.py erase_flash”) but the problem was there from the beginning of the fresh installation.
I just got another banch of the esp32 from AZ-Delivery (Amazon driver was here 6 minutes ago) and tried to install WLED (via WebInstaller) on a completely new, untouched ESP32.
=> exactly the same issue. After turning off the Time Controlled presets, the rebooting stops
Exactly what version are you loading on an empty ESP32 from the Web installer?
The lastest version 0.13.1 (Browser google Chrome).
I did it on my PC (Windows 10) and on my Surface (Windows 11, there I had to install the Windows driver [CP210x USB to UART Bridge VCP Drivers - Silicon Labs] before the Web installer worked)
BTW: Thank you very much for your help!! (still no reboot :slight_smile: )
Edit: On the AZ-Delivery ESP32, i had to press the Boot button to make the web-install work
As always, I’m willing to take the credit if your willing to do all the work :stuck_out_tongue_winking_eye:
:rofl:
But I’m still wondering, why I am the only person, where this behaviour appears, with different manufacturs and different PCs…
Just wanted to do a follow up here:
New installation of the new 13.3 Version => No reboot problems any more :smiley:
Thank you!
i am trying to build a facial recognition trigger project but i keep getting this on the serial monitor arduino ide :
SOMEONE PLEASE HELP!!!
rst: 0xc (SW_CPU RESET), boot: 0x13 (SPI FAST FLASH BOOT) configsip: 0, SPIWP: Oxee
c1k_drv: 0x00, 9_drv: 0x00,d_drv: 0x00, c0_drv: 0x00,hd_drv: 0x00, wp_drv: 0x00
mode: DIO, clock div:1
load:0x3fff0018, len: 4
load:0x3fff001c, len:1216
ho 0 tail 12 room 4
Load: 0x40078000, 1en: 10944
load: 0x40080400, 1en: 6388
entry 0x40080664
