Hello community.
GPIO 16 pinout for first data out.
Which GPIO is used for seconds output on ESP32 ?
There are lots of possibilities, checkout ESP32 pinouts for a table of the choices (look for Green outputs with no described issues).
Just update the WLED config with what you choose.
Your board may or may not have similar numbering, do you have a board (or one in mind)?
If you check the link I sent, that is specifically for the ESP32.
Looks like a neat project.
Thanks a lot. I need also 3v and 5v for level shifter,i found 3v but 5v i dont see.
I providing 5v to VIN ,is it OK to use same for 5v on level shifter ?
You can safely use the same 5V supply for both the ESP32 and the levelshifter as the shifter uses very little power. Just make sure you’re using one of the types suggested in the KB: Level Shifters If you use a 74AHCTxxx type, you only need 5V.
