Esp32 won't start wled server
I flashed wled to an esp32 wroom using the installer
It worked and everything worked as it should including led strip control
I disconnected the esp32 and reconnected and the web gui won’t come-up
I do see wled device on the wifi list with a different ip then the wled server
Both ip does not work.
Any idea what went wrong and what do I need to do to fix it?
could be bad hardware, seen it before.
try if uploading the nightly build does anything different.
It wasn’t connecting it using the pins instead of the usb port solved the issue
