Ethernet Port Hi speed flashing LED
Hi, When I connect my QuinLED Digi Uno (with ESP32 Ethernet) from its ethernet port to any device using a ethernet crossover cable, the LED flashes about 4 times a second. Pretty fast. There’s no data being transmitted. I even tried connecting it to a network switch with nothing else connected and its still flashes really fast. Any other device to device (e.g. two windows laptopsI have tried when connected via a crossover cable seems to only flash when data is being transmitted.
Is this a problem ? If so, any ideas on a fix?
WLED uses mdns and also sends broadcast packets for other instances or the mobile app to discover it, so normal.
