i will build lamps to illuminate a segment of a gabion, which is filled with glass stones. I want to build four lamps with five strips off 12 LEDs each. They should be in vertical orientation. I can wire they from bottom to top each stripe or in zig-zag bottom - top - top - bottom… My problem is, that only 10 segments are possible in WLED and I need 20. Because each stripe can show the same pattern, is there a solution which makes copies from the first segment to all others? I found no solution to represent the fire flicker effect in 20 segments. Other effects are easier to represent, but the fire flicker is heavy for me.
I use a ESP8266 controller with WS2815 LED-Strip.
