I have two LED-strips, both WS2815B connected to separate MCU´s, flashed with WLED_0.9.0-b1_ESP8266.bin.
They share the same 12.5 A powersupply, and both LEDs get powered (12v) directly from the psu.
Ground goes from the psu directly to the MCU´s.
The D4 data pin is connected to the backup data wire on the LEDs, since the primary connection seemed faulty.
One MCU is is power from a USB, the other through a 12V-5V DC-DC converter (3A).
This last LED connected to the non-USB-powered MCU is flickering once in a while, say each 15 seconds (see video). It dips to black or to an other color in its full lenght (288 LEDs).
Since this morning I have:
- swapped the non-USB-powered MCU with a new one, and flashed with
WLED_0.9.0-b1_ESP8266.bin. Connected the new MCU to USB power. LED´s still flashing as before. - Swapped the data cables, between the LEDs, so that they would get the data signal form the other MCU. LED´s still flashing as before.
I might add: The blue/red slips above are both set to low brightness, and solid effect.
When changing effect from Solid to e.g. Dynamic there is a way more lightening effect.
See below:
I´m closer to a solution, but I cannot figure out why this LED is flickering… Any suggestions?
