Hi folks, what really bothers me is that slow moving effects are really not smooth because the LEDs just display frame after frame with no interpolation. I use a 5 meter strip with 300 LEDs (actually it’s 9meters on my install but just for reference) wich should be plenty but you really can see the steps it does on slow moving effects.
Wouldn’t it be possible to compare the previous “frame” with the next one and inserting a frame in between with interpolated values for each led ? This should smooth out movement alot I think. What do you think ?
I figured those must be 60LED/M then.
Alright so: I experienced same thing actually while other effects are smooth. I compensate that a bit by increasing the amount of max Frames in the LEF Preferences as @TheLight3r mentioned
