Hi all,
Brand new WLED user, first time setup, somewhat confused ![]()
I used the online installer to successfully load WLED onto my NodeMCU clone.
While powering it via USB, no LEDs attached, I configured it for a full 5-meter SK6812 led strip: start at 0, length 300, GPIO 2.
For some reason ‘info’ indicates that it is running at only 3 frames per second. This is confirmed by the blue LED flashes, and connecting an oscilloscope to the output pin shows a short burst of data three times a second.
Under the Advanced configuration, target refresh rate is set to 42 FPS. As a test I tried setting it to 1 FPS but that had no effect.
Changing the number of LEDS in the string does not affect the frame rate either.
I haven’t seen any reports on the forum for an issue like this (did I miss one?).
I have not yet connected the LED strip to see if data is being transferred properly- I was kind of hoping to ensure that the system was basically working before connecting the expensive LEDs…
I consider myself a fairly experienced micro-controller user and programmer but I’m unfamiliar with this application. Does anyone have any suggestions on what might be wrong (misconfigured?), or what I could try in order to troubleshoot this issue?
