Govee H7057 (Govee Outdoor Flood Lights 2) Will they WLED - YES!
Good Day all!
So i took a leap of faith and cut the controller on my H7057 to get them into WLED. All works fine, you will need to set some presets for RGB/White/Yellow to save you messing around with Segments. However they will work!
Below are my settings I got them to work with my DigUno. White cable is Data, Red +, Bare shielding is Ground.
Can paste my pre-sets if anyone needs help, but you should be able to tweak and figure it out.
Couldnt find any record of it being done, so thought ill post to say its working.
