Grouping of strip leds for artnet controling
Is it possible devide strip to group pixels ?
for example- i have strip with 60 rgb leds.totally its 180 dmx channel.Is it possible make 20 pixels where each new pixel now contain with 3 phisycal pixels.Totally it will be 60 dmx channels and all strip used.
yes, use grouping in segments.
It’s work only for internal effects?What I do wrong?where is settings for make segment for artnet dmx using?
not familiar on how artnet protocol is imlemented, sorry. if grouping does not work over artnet, then I do not know if there is a way.
Use “main segment only” in settings. Then grouping will work.
I think the requested function makes a lot of sense. I would also like to see the implementation of a new DMX/Artnet mode. Similar to the Segment Effect mode, this mode should allow control per segment, but with only 3 (RGB) or 4 (RGBW) channels instead of 13. This would greatly simplify the use of addressable LEDs in stage lighting.
