Hi all, any idea if I can use the following led strips I already have with WLED?, I don’t have much info on the strips or chip, but I know 3 RGB Led’s are controlled per chip, 2 before and 1 after each chip, just discovered WLED, and would love to be able to use it with my strips, as the current controller is Bluetooth only.
Amazon Link>
Listed as “RGBIC Rainbow effect”, “DreamColor LED”
Actial product Pic: Only allowed 1 pic as new user.
I’m not positive, but it sure sounds like WS2811 strip. But if that is what you’re looking for, I’d recommend you know what you’re getting and from a reputable manufacturer. https://www.amazon.com/dp/B01CP5PQU6
This one is cheaper, probably because it doesn’t come with power supply and controller. But if you’re going to use WLED any way, there’s no sense paying for something you’re not going to use.
Thanks for the response, but I already have the strip installed wrapping the entire room at the ceiling level “50ft”, trying to figure out if it’s compatible.
So I just tested it out but it doesn’t seem to properly control the strip, switching between colors or effects only seem to affect the first 2 or 3 segments, and the color isn’t correct “flickering multiple colors”, however, I did notice that if I choose a solid color and power cycle the strip only, it seems to power on with the correct color.
FYI: see below, if relavant or maybe help someone else, not sure if the info from this device can help with getting WLED configured to control these strips.
I got the device linked below which works to control the strip via the MagicHome App, specs state “Supported Driver IC: WS2811,WS2812B,SK6812,WS2801,UCS1903 ect.”, not sure which is the one I have, but this works, just thought it may be some useful info.
