I want to disable blynk and some other sync features which I don’t use.
here is my build file (platformio_override.ini)
[env:nodemcuv2]
board = nodemcuv2
platform = ${common.platform_wled_default}
platform_packages = ${common.platform_packages}
board_build.ldscript = ${common.ldscript_4m1m}
lib_deps = ${esp8266.lib_deps}
build_flags = ${common.build_flags_esp8266}
; -UWLED_USE_MY_CONFIG
; -D WLED_DISABLE_OTA
-D WLED_DISABLE_ALEXA
-D WLED_DISABLE_BLYNK
-D WLED_DISABLE_HUESYNC
-D WLED_DISABLE_INFRARED
-D WLED_DISABLE_WEBSOCKETS
But it doesn’t disable the above features. What am I missing here?
flags
[esp8266]
build_flags =
-DESP8266
-DFP_IN_IROM
-Wno-deprecated-declarations
-Wno-register
-Wno-misleading-indentation
; NONOSDK22x_190703 = 2.2.2-dev(38a443e)
-DPIO_FRAMEWORK_ARDUINO_ESPRESSIF_SDK22x_190703
; lwIP 2 - Higher Bandwidth no Features
; -DPIO_FRAMEWORK_ARDUINO_LWIP2_HIGHER_BANDWIDTH_LOW_FLASH
; lwIP 1.4 - Higher Bandwidth (Aircoookie has)
-DPIO_FRAMEWORK_ARDUINO_LWIP_HIGHER_BANDWIDTH
; VTABLES in Flash
-DVTABLES_IN_FLASH
; restrict to minimal mime-types
-DMIMETYPE_MINIMAL
