Help with wiring with x2 power supplies and x4 strips
I’ve been looking for schematic on how to wire x4 ws2812B (5m each with x2 120w power supplies using one esp32.
Can anyone help with the wiring for this?
Will I need a lever shifter?
Should I use any resistors/capacitors?
Any help much appreciated
D
Generally, you want your power evenly distributed amongst your strips.
With 4 strips (A,B,C,D) joined as A->B->C->D and 2 power supplies (PS1, PS2) the simplest layout is to try and power the AB pair at the A->B join and the CD pair at the C->D join.
An explicit ground wire common between all strips and power supplies is required.
There should be no connection of the power line between B->C, only data and ground.
Data is fed into A only, power for the ESP32 can come from either PS1, PS2, or even a separate power supply as long as the ground line for the ESP32 is connected to the other PS grounds.
Depending on distances involved, you may need more power injection and/or a level shifter.
Thank you very much for detailed response.
All makes sense now.
Do you know if I would need any resistors or capacitors?
Lastly, how would I know if I need a level shifter?
Thanks again
D
I personally have never needed the larger (1000uF+) capacitors suggested in some diagrams.
I attribute that to working harder to ensure there is good power to all parts of the strips.
Similarly I don’t use inline data resistors
For me, the MCU is either very close to the data start or I use a TxRx pair to make the data source close.
I would assume you need a levelshifter rather than the opposite - note a TxRx pair is also a levelshifter so if you want your MCU a long distance from your strip(s) that’s already covered.
Make sure you have fun with stuff :wink:
