Hey! I change MAX_LEDS_DMA to 540 (i have a 540 leds), but always not work! I think i need to change UI config. I look at html_settings.h, but no results . But 500 leds works good and all work! Please help with it :3
Hey!
Change line 274 of xml.cpp
to oappend("d.Sf.LC.max=540;");
Thank you very much for fast answer! Now all is work!
Should that be hard-coded like that?!
No, that will be changed in 0.12.0.
I still want to keep people from entering into an out-of-memory bootloop because the entered a 0 too much on the LED count, but the define in const.h should ideally change the value in xml.cpp as well
