I have a pretty odd situation where I have a WLED install at the end of a long run on my landscape lighting circuit (12VAC). I have a 12VAC to 12VDC converter and it works well, but I think because I’m near the end of the line and voltage is prolly down to around 11VAC, it takes a moment for the voltage to stabilize when the landscape circuit comes on (it has a buck/boost in it, so even at 11V in, it puts out a clean 12VDC)
This has not been a problem with the WLED controller. But the WS2812 “seed” string lights are not handling it well. About 50% of the time, they act like half (or more) of the string is not responding/“burned out” and only the first 20-100 LEDs will respond.
If I leave the PS and WLED controller powered up and disconnect the LEDs Xconnect plug for a moment and re-plug, all is well and all LEDs are responsive. But that isn’t terribly practical for an outdoor setup.
From what I’ve been reading, it sounds like, just maybe, the “slow ramp” (over maybe 2 seconds) can sometimes cause the little processor in the WS2812 to lockup and after that, it won’t get better until there is a power cycle.
All of which leads me to wonder if there is a way for WLED to not send anything to the LED strip for some period of time (like 2 second) before even trying to talk to them. I’m not 100% certain this will work (it’s possible its the power supply coming up slow causing the problem and not the “trying to talk to them before things have stabilized”, but I’m checking out all options.
The PS itself doesn’t spike or anything - it ramps up pretty smoothly without overshooting and the output looks smooth on my portable scope.
May be barking up the wrong tree, but thought I’d ask ![]()
Gerry
