I was a Navy Electronics Technician Nuke, but I only troubleshot and maintained electrical systems, not designed them.
I understand the nuances of voltage, current, watts, loads, fuses, and controllers. One size and one answer does not fit all.
I have successfully gotten this system to work. My lights blink and dance on cue. No problem with the ESP 32 C3 controller, or the WS2812B RGB 60Pixels/m LED light strings.
I have reviewed the WLED instructions here:
https://kno.wled.ge/features/multi-strip/
My question is one of safety, wire size, and fusing.
I have measured for 6 LED strips for the outside of my house. 9 segments of varying lengths from 24 inches to 182 inches. Power and control will be from one end in the garage. Using a 5v 45 amp power supply. It will be an approximate total of 1586 LEDs
I know I have to power inject at the junction of each strip.
How many strips can I wire per fuse? And what fuse size. I know I could wire them all individually, but I want to minimize the number of wires tucked into the soffit. and of course the expense of duplicating wires unnecessarily.
What size wires and where are those sizes required?
I started with 20 gauge 3 strand wires, but I think this is not adequate. I have 16 gauge wire on the way.
Can my ESP 32 controller talk to the entire strip, or will I have to break up and solder to another output?
Hopefully I have included adequate information for a complete answer.
Thank you in advance.
