Hey!
I have 4 “power towers” that I’ve added LED strips to for a high school band show. My goal is to have them all connected through the WLED app and turn them on and off at different times during the performance.
Here is what I have:
ESP32
LED Strips - https://a.co/d/bUiHINS
Antenna
USB for ESP
Jumpers (ESP to LED)
WAGO
Wire (LED to LED)
LED Connectors
LED Power Supply
Router
(I had links to all, but had to delete for the post)
I also have 12V batteries connected to an inverter that power the ESP & LEDs.
The LEDs power on, let me change colors & set effects, and change brightness level. Unfortunately, they keep flickering different colors. Here is a video of that: Prop LED issue - YouTube
I believe it’s a problem with the ESP. When I disconnect the ESP from the LEDs, they will stay 1 color and not flash. I tried disconnecting the data and ground and both kept the lights 1 color without flashing.
Anyone have any idea what the issue might be?
More info:
- ESPs have connections to “2” and “GND”
- The LEDs are red when they have power but are turned off in the app
- I don’t believe it’s a power issue, as they stay lit on 1 color when disconnected from the ESP
