Leds wont work past 700
Sounds like a bad connection, if they go bright sometimes. How did you splice the strips together? If you used those little splice clips that you can buy I would check that spot as those are notorious for making bad connections.
thanks i will try multimeter and i have solderd the cables all together but i will look into this too
