I have an ESP32 running two SK6812 strips from GPIO 2 and 4. The strip connected to GPIO 4 will wig out for a split second every 5-10 minutes, where it’ll change to a different color and back very quickly. Oddly enough, the data wire on the GPIO 4 is much shorter than the strip connected to GPIO 2. I believe my hardware is solid. Any troubleshooting suggestions?
Swap strips and see if the problem follows the strip or the GPIO.
Try different GPIO(s).
Get up to the latest WLED version.
