Lights flickering when a 2nd/3rd data pin is added
Hey guys, thanks for any ideas/help on this topic. I’m running 2,295 BTF WS2815 RGBIC LEDs with the sound reactive WLED 14.3 version controlled by a ESP32 with a 300 watt driver split into three 100 watt +/- cables. First 100 watts is for the ESP32 and the other 2 are used for power injections. Voltage at the end of the strip is 10v. 6 months ago I dialed everything in with the old sound reactive version…12.6 or something and everything worked flawlessly…no lagging…no flickering…ect. When I updated the ESP32 with the new sound reactive version it cut off the LEDs at 2048. I added another data cable to GiO D4 PIN…the rest of the LEDs came on but flicker every 10-15 seconds. Split into 3 data pins and D2, D4, D5 (Less than 800 LEDs each) and the last group would flicker. Split it into 4 data pins and the last group would flicker. For some reason the last group of LEDS are flickering. Its driving me nuts knowing that it used to work with the old version but not the new version. Any input on this would help me out a ton!!! Thanks
Try with less than 300 pixels per output.
