Lights Turning On Again After Power Outage on ESP32 and ESP8266 Boards
“I am using ESP32 and ESP8266 boards, and I control them only through the onboard controls. However, there’s one issue: when the electricity goes out and comes back, the lights turn on again. How can I solve this? Please help.”
Uncheck turn leds on after power up/reset
Or make a boot preset that is black and add it here
Or use the Autosave usermod for last state .
By the way, thank you for your help. I tried one of the methods you mentioned, and it worked. I just have one more issue, and I would appreciate it if you could help.
When the power goes out and comes back, my devices lose their old IPs, and each device gets a different IP address, not keeping the old ones.
You would have to reserve a static ip address in your wifi router.
Thank you, it worked. However, another issue has arisen. After turning off the lights, when I turn off the first LED on my ESP8266 board, after a while, only the first 3-4 LEDs are turning on, just like in the picture. What should I do?
Picture link : iCloud
