Allow for selecting a preset index to load when to power is switched on.
I use wled to control strips as under cabinet lighting.
By default these will run the Spots effect.
To reduce risk of fire (and reduce power consumption) the power supplies are switched off when not required. When powered on, wled shows the default orang-ish solid, which is changed to the spots preset when the presence detection in Home Assistant kicks in.
I would like wled to have a setting that allows to load a preset by default on boot.
Would anyone else like to see this added as a feature?
