Hi @divsys, can you confirm if my wiring below for the Max485 is right ?
Not too sure about the RO-RE-DE-DI part but gave it a shot based on this
RO - Receiver out
RE - Receiver enable (enabled when this pin is LOW)
DE - Driver enable (enabled when this pin is HIGH)
DI - Driver in (the transmitter pin)
I guess I could also use 12v-5v step down converters to feed the transmitter/receiver and go from 5 wires to 4 wires
As per your other thread
Also, what are the terminals blocks for? just another way to wire A-B ?
Let me know what needs to be corrected, unless I’m right =)
Thanks.
