Modified IKEA LEDSJÖ wall lamps with WS2812B + ESP8266 (synchronized)
Hi!
I wanted to share a small project I finished a couple of years ago, .
I’ve modified 2 × IKEA LEDSJÖ LED wall lamps and added addressable RGB lighting around each lamp.
Concept
Each LEDSJÖ wall lamp consists of 5 round lights, and around each one I mounted 4 × WS2812B LEDs.
That gives:
  • 4 WS2812B LEDs per light
  • 5 lights per wall lamp
  • 20 addressable LEDs per wall lamp
  • 2 wall lamps = 40 WS2812B LEDs total
Control & electronics
Each wall lamp is driven by its own ESP8266, mounted inside the housing.
The ESPs are configured to:
  • Run the same firmware
  • Be synchronized with each other (same colors, effects, and timing)
  • Control the WS2812B LEDs via a single data line per lamp
The power supply for the WS2812B LEDs is separated from the original LEDSJÖ electronics, so the original functionality remains untouched.
Result
The result is a wall installation where both lamps:
  • Run perfectly synchronized
  • Can display animations, color transitions, and static colors
  • Create a soft RGB glow around each round light
Great as accent lighting in a gaming room, living room, or as decorative wall lighting.
Photos and a video of the final result are attached below :backhand_index_pointing_down:
Feel free to ask if you want details about wiring, code, synchronization, or power setup!
