Multiple PWM-Output TLC5947
Hello,
i get my TLC5947 running on the Wemos D1 mini - it is able to drive 24 discrete PWMs/Leds.
Now i want to use it together with wled.
I want to use them to light up some lego models - together with the WS2812b
What would be the right approach?
I thought of implement them within a own segment and special effects, which has to be selected with this segment(s). The brightness can be used from the master-slider.
Other idea: extend the amount of leds within the ws2812b-strip an read out the values cyclic to put use them within the TLC5947
Any other solution?
Any hints will be helpful…
Hi there,
I also have a setup with 13 PWM-LED strips that are RGB and therefore require 39 PWM outputs.
For this I use two TLC5947 boards from adafruit. These boards can be chained.
However, I use raw Arduino Code which does work, but effects have to be integrated … In short it was great if wled could just control those PWM drover boards.
Any progress on that 4 years after the OP?
Use WS2811 external chip, it is well supported and since 0.16 can be used as individually addressable white only.
These might be useful:
https://www.aliexpress.com/item/32786272573.html
