My WLED lights are turning on intermittently
My WLED lights are turning on intermittently. How to fix?
no need to answer. i answered my question. Thank you!
C’mon - and the answer was??? (it’s helpful even if embarrassing)
I read it in one of the post. My lights kept on turning on every hour because i programmed it by 24 hour and 00 minutes and preset it ID to run the preset at 12AM. I did not know that 24 hour is actually turning on that preset id every hour. Maybe they need to add something in the knowledge section regarding that. I am sure people are banging their heads on how to fix it. I sure was banging mine :).
Thank you!
This is the kind of real-world info that helps everyone.
It might even push some changes for the screen prompts to clarify things…
Good call! My pull request was accepted last night, this info has been added to the knowledge section!
Great!
Question regarding mirrors effect for 2 lights that are not the same length. I have 2 peaks at my house and I want to mirror the effect in both peaks and hit the peak at the same time. I am using digquad and outputting the leds in separate outputs. Is there a way to do this? Thanks in advance!
Best,
Al
I don’t think there’s a short answer to your question, but it should be possible!
Check out the effects and segments pages on kno.wled.ge
I suspect that some effects will work natively, and many others will work if you get creative with how you define your segments. If you define each peak as two strings and reverse the second string, it should get pretty close to what you want!
Hey Mjg1088,
Question. I am trying to cycle to all the affects and step 1 by 1. I have this api call but i am not sure if i am going about the right way. Do you mind taking a look? What i am doing wrong here.
http://192.168.1.228/win&FX=~&TT=10000
Please don’t post the same question multiple times.
Delete this one and wait for a response to your other post.
Ok, I will.
Thanks,
Al
