I have tried to put in a UTC offset, which works, but by the morning the time is completely wrong again. I thought it may be a connectivity issue because I think ive set it up correct, but even with a booster 10’ away the Hours/Min are way off in the morning.
I have never been able to get the Year/month/day correct.
Hey @huggy-d1, I tried various addresses for NTP services but still can’t seem to get things set up using the app. I used my home router address, google ntps (8.8.8.8 & 8.8.4.4) and a few other ones that I have found online, but nothing seems to get it remotely close.
I’ve reflashed my esp8266 from v10.0 to v10.2 and still have issues. I’m actually using 4 esps on my house lights, and I can’t get any of the esps to work. After the flash the time shows 1970, and after I enter an ip address, the time always seems to go to 2106-02-06, 23:30:00 - doesn’t matter what time of day.
I tried putting an off set in, cause I don’t really care about the date. But even with an offset, the time drifts by the morning.
DrZzzs posted a YT video over the weekend about configuring WLED. He has a small section where he configures NTP. Perhaps locate it and fast forward until you find that spot in the video and see what Dr Zzzs does differently.
Hi… I have some kind the same issue. running ver. 10.2 ESP8266.
Now, as long as its connected by usb, it gets the proper time and date.
As soon as I disconnect it and wire it, time and date (NTP) are set to1970.
Tried different servers, checked the router (tired different settings, portforwarding) and I even connected it to a open WiFi (default AP settings). No good… anybody a better idea?
I tried it with 3 seperate MCUs (reflash with wipe), still no good.
@Galatron I haven’t had any luck either. I have tried everything that you mentioned, and I can’t figure it out. The curious thing I have found is that every time I reset it, the NTP always goes to Feb 6, 2106, 23:28:30. Doesn’t matter the date, or time when I reset it.
Honestly, I gave up on it.
I am using a Raspberry Pi and running Home Assistant to get things working. The one benefit to HA is that the ‘on’ can be set to ‘sunset’ with an offset if desired, so I don’t need to continually change the on time as the night gets earlier up North here.
