Hi, it’s a while I’m not using WLED and I don’t remember which version I used, I know it has .backup extension, now it accept only .json files. I’ve tried with verison 12 but not backup at all, version 13.3 alteady has .json, ho can I restore my effects? Which version should I install and after this to which version I need to upgrade bufore upgrade to 15 version? Thank you!
EDIT
here is the file
this is not a WLED Backup.
looks more like a backup of a router or firewall
dear friend, you’re right. Looking deeper on file I’ve found infos of router, who knows what that day made me write on that file “wled”. So I?m ut of backup and I’ve to rebuild all from zero, too bad, good lesson for me on next time.
You assure me wled always used .json flles for backup, right?
I can’t guarantee that. I haven’t known WLED long enough for that.
WLED introduced .json files for backups from the menus somewhere in 0.13.
There may or may not have been a good facility in 0.12.
