ciao, nobody has this issue?
If in LED PREFERENCES Led Output set the length is over 399 no more light…
Almost in all new releases…
I’m crazy or dumb?
Thanks for any responses
What controller are running?
What version of WLED do you have loaded?
What does your setup look like?
Hi yes sorry…
ESP32 4M
WLED tried from 13 to 14 hoshi and last releases. Even many version of Moon Modules.
I’ve connected 2 or more 8x32 ws2812 led matrix.
When 256 leds everything work perfect, when I add a second panel for 512 leds it stop to shine but if I set Led Output Length to <400 it return to shine correctly until 399th led.
I’ve tested every configuration hundreds of times…
Do you have any ideas/suggestions?
thanks a lot
How are you powering them?
No power problem!
huge 30A 5V for only 2 8x32 panel matrix at low brightness.
I’ve really considered all the basics…
Are you injecting power or just powering it from the beginning?
Do you have the brightness limiter set/set too low in LED Pref’?
ok everybody seems converging towards a power problem…
I’ll try with different power options even if I had not this problem before.
I let you know thanks
