Dear community,
Consider the example:
- Segment1: LEDs 0-10 (switch on and selected)
- Segment2: LEDs 0-5 (switched off and deselected)
In this combination when the effect is applied to Segment1, LEDs 0-5 (overlapping region) start flickering. This is unexpected, because Segment2 is not active. I would suppose that Segment2 should be completely ignored in this case.
When I remove Segment2, the running effect on Segment1 immediately continues to run without any issues.
Note that I am not trying to run same/different effect on Segment1 and Segment2 simultaneously (as mentioned in LEDs Flashing with Segments and Segment-layering without flickering).
WLED v0.13.3
