Pixel stuck on red
I recently installed christmas lights using ws2811 pixels and the dig octa. Ive discovered that one pixel is stuck on red regardless if I change effects, colors, power wled off or change a number of wled settings and resistor. The only way it turns off is by turning off the psu. The green and blue within the pixel still work fine but the red stays on no matter what. Has anyone had a pixel fail in a always on configuration? Looking for another solution as i most likely will have to replace that pixel which is of course located on the highest and most challenging section of my roof.
You can try enabling the ‘Off Refresh’ check box in Led Preferences. If that does not get it to turn off then you would need to replace it.
