Is it possible to host WLED on a computer running Windows? I’d like for the Windows machine to generate the LED data and send it to all of my esp32 devices running WLED via DDP. I know that I can do this with an esp32, but what are the limitations of doing so. Can one esp32 handle sending data (5000+ LEDs, multiple segments, multiple effects) to 10+ esp32 devices via DDP? I’m sure I can do this with xLights, but the simplicity of WLED is hard to beat.
you can send the data direct to the controller via IP
or you use for a sequence the Terminal a Batch file that sends CURLL data
curl -X POST “http://192.168.2.100/json/state” -d ‘{“on”:true, “bri”:25, “seg”:{“i”:[
0,15,[0,0,0],14,30,[0,255,0]]}}’ -H “Content-Type: application/json”
