Power Limitation as of External E131
Hi i discoverd using the E131 Protocol from External via WIFI to drive the LED consums more then
the Config entry
Is this right
or is it somthing that is 0,15.b7 as i think this has not been the case in 0,14
Thank you
Possible , compare it to old builds and post a bug report if you discovered an issue .
For large setups ( not really that large but 64x64 ) a lot of the apps I tested did not do that
well which included Jinx , Hyperion and HyperHDR . I was only able to barely use the 64x64 with xlights with DDP and most effects are not that great on esp32 with wifi .
I have no eth esp32 to try and compare but only commercial cards
Just noticed you said power in your subject but not in the body of your post so might be you are referring to another thing
