Problem with govee curtain
So I recently got a set of the govee curtain lights which is pretty exciting. I’ve been wanting to check out the matrix. So I’m using an esp32 dev 1 board with the latest wled as of today, the govee power supply, which outputs 5v, 5amp, 25 watts. I opened the govee controller to verify which was positive, negative and data, then clipped the power wires feeding the controller as well as the wires feeding the lights. I have a positive jumper wire soldered to the VIN pin, one beside it to the GND. For data I’ve tried 2 different gpio. Gpio d2, and 16 (which according to the pinout sheet is 2 pins to the right of d2 and its marked rx2. I then soldered the positive from the power supply as well as the positive to the lights to the VIN jumper wire. Repeated the same for the ground wire, an finally the data to first the d2 pin then tried the rx2 pin. Each time when I go to plug it in, the board powers up, but only 1 single led lights up on the 25th string an 12th led down. I have also tried powering the board via its USB c port an had the power supply positive only running to the lights and not the board. (GND was still tied into the board and lights tho). I am stumped. I don’t get what my mistake is. I have also gone into the wled app an changed the settings to 2d matrix, vertical, 20x26, as well as led preferences an set the amount to 520. Definitely could use some insight here
what type of LEDs are they? Govee uses several unusual types, not all are supported.
Where can I find this info? I’ve checked the manual. The model is h70b1
