Need help on how to run 22 strips of 144 led’s @ 3.2 ft each.
How many strips should i run each esp32 and how to go about powering it all?
They will be going on the ceiling of my living room in the quarter round diffusing channel.
Room is aprox 23x13 if that helps.
You’ll probably have to provide more information before anyone can help much.
A good start would be to draw up a diagram of how you think this will look on your ceiling, and what you expect to do with it. Total number of LEDs and how many ESP32(s) will be useful.
From there, you’ll need to work out what the maximum power requirements will be and how you think you’ll power it all. Led voltages, maximum current use and distances from the power supply(s) will be critical.
