PWM White not working at all
Hello everyone,
I want to make simple led controller for 12V LED strip (simple 12V strip) but I’ve issue with configuration. It’s dead-simple but I can’t get it running. For type “On/Off” it works but for “PWM White” it doesn’t work at all, led strip doesn’t turn on/off and I can’t control brightness.
I’m using latest wled release 0.15.3
Here’s my LED Configuration:
I’m crossing out hardware issues because on ESPHome it works flawlessly (on/off, brightness control)
Here’s ESPHome snippet for reference:
YML snippet
output:
  - platform: ledc
    pin: GPIO16
  - platform: ledc
    pin: GPIO17
light:
  - platform: monochromatic
    output: led_pwm16
    default_transition_length: 1s
    output: led_pwm17
I’m using this board:
https://pl.aliexpress.com/item/1005009869746188.html
Any help would be much appreciated :slight_smile:
I’ve figure it out. Option “Auto-calculate W channel from RGB” should be set to Max
Thanks for Posting the Solution. Ran into a similar Problem. With 2 Quinled Penta Deca and PWM White Stripes. Many FX worked with Auto caluculate W Chanel to “none” but some 2D and the Image Player did’nt light up at all. With “Max” it works.
Now I can further try to use Image FX for playing very slow .gif Animations
