I have an ESP32 running WLED, I tried both 0.13.3 and 0.14 to fix my problem to no avail.
There are two 24v ledstrips connected to pins 4 & 5 using two PWM boards that regulate 24v voltage to appropriate levels. The 2 strips are configured as separate segments.
From the WLED webinterface every works as it should, I can dim the strips separately etc…
However I want to control the ledstrips from Home Assistant and this only partly works. I can set the brightness of the segments by using the entities ‘lights.wled1’, ‘lights.wled1_segment_1’ or ‘lights.wled1_main’ for overall brightness. But this only works when I set the slider called ‘white channel’ (version 0.13.3) or ‘Fx’ (version 0.14) in WLED to 100% for example. After a reboot of the ESP32 the sliders are always at 0 and controlling WLED from Home assistant doesn’t work because of this.
I haven’t found any entity in Home assistant to set this value, does WLED not provide it to Home assistant? Or is the problem on the Home Assistant side? I spun up a vanilla Home Assistant instance but the problem remained the same. I looked at the palette entity, but nothing I could see to make it work.
