Control each single LED of a WS2812 RGB Strip
Hi there,
i want to control each single LED of a 2 meter long LED Strip (288 LEDs) out of Home Assistant.
I’ve tried this with the JSON API with following command:
curl http://172.16.200.52/json -d '{"seg":{"i":[20,"FF0000"]}}' -H "Content-Type: application/json"
The command suceeds, but no LED would lit up.
Is it generally possible to control each single LED of such a long strip?
For the Moment i have splitted the strip into 15 segments and i control these out of Home Assistant.
Thanks for your help!
Try adding "on":true,
Yeah unless you unit is on to start with you need to add “on” to your json ,the way i did that is with a loop , also you could use presets with the same command
I haven’t dealt with it for a while now, but would like to tackle it again:
The reason why I want to control individual LEDs is that I want to display the progress of a film in this way.
@ALDIY I don’t quite understand what you mean. Should i create 288 Presets to control each single Led?
All I have found out is that it is apparently not possible to address individual LEDs in WLED.
Since you are using HA , use a loop and just change the led number .
A simple tool was also made after that post might give you ideas
I a was also away from wled for a while so a bit rusty
A simple example i did from a dos batch file is below
But as i understand, you are still adressing segments? Is this correct?
I did not want to control segments, because they are limited to 16 on a esp32.
So i wan’t to get away from segments and control each single Led from HA.
@deadrabbit87 the seg is the configured stripe as there is no number (i) it means the full stripe
