I have a random flickering issue with a third pixel string I added to my DigQuad. I’m using 12V seed pixels purchased from AliExpress. Strings are all good, I know, because I used them with a previous setup with no issues.
With my DigQuad (running WLED 15.2beta, downloaded from quindor github), first string has 103 pixels, connected to GPIO1 (LED2 on the DigQuad), second string has 134 pixels, connected to GPIO3 (LED3 on the DigQuad). Both of these have fairly long run from control box to first pixel (about 25 ft first string, and 12 feet second), using three wire conductor, and switching the resisitors on the DigQuad to 33ohm. These have been working fine, with no issues for about 3 months. Power supply is 12V 300W (25A) supply.
Problem is with my third string, which has 414 pixels, and have just added. Run from control box to this string is only about 3 feet. If I hook this up to either GPIO16 (LED1) or GPIO4 (LED4) on the Digquad, I get random flashing of this string, and only this string. In my previous setup, I had this string attached to the DigQuad by itself, with no issues whatsoever. I replaced the three conductor cable I initially had, with three separate wires (power and data), but that didn’t seem to make any difference (and interestingly, with the separate wires, I still have to have the resistor setting at 33ohms, or I get even worse flickering – I thought with separate wires the 249ohm resistor setting should be fine for a 3 foot power/data run??). Power to this string is only at one end - could this be the problem? I had it set up like that previously though when it was the only string, with no issue.
I have checked data/power connections between the string and the DigQuad and they all seem secure.
