I must be blind but I don’t see how to get a razer app id, and google only give me result for razer synapse id
hello, this program can work with several wleds right? so wanted to know each wled is recognized individually? I wanted to make an ambilight using razer as a screen reader
As far as I remember Razer only passes 1 or maybe 2 colors at a time. I don’t think this would work as an ambilight solution.
I would look at Hyperion.
I’ve been testing the beta version of the WLED integration of SignalRGB. It’s still being developed but already working really well.
I open the integration program and it closes by itself another bug I don’t know if it’s just my notebook (laptop)
Are the LED’s individually addressable with Razer Chroma and WLED or will the entire strip have the same color? Maybe someone would be kind enough to show a screenshot of what this looks like in Chroma?
I’m new to all of this but I want to integrate my custom LED’s with Razer Chroma. It seems here I need to follow your instructions and actually create the app myself? Is there no way to just download and install it?
Just a quick question. I am running wled on an esp32 and am using 3 i o pins on the microcontroller. there is a 300 led strip on pin1 and 4 and a 600 led strip on 2. When I use WLED connect for razer synapse, it will only let me use 2 sections totaling 424 LED’s. if I enable another section od select entire strip, it locks on the current color and will not change or work at all. Only the 2 sections will work and only when those are the only 2 sections enabled. Any ideas?
Hello, I have a problem, no matter how hard I try, I can’t get the LEDs to change color with the program, Razer detects the program and the program detects the LEDs but the LEDs stay off when I try to change color with the program.
I use 2 3-pin LED strips together of 300 LEDs each (600 total) and an ESP8266, how do I get it to work?
I can’t get RazerChromaWLEDconnect to start anymore. I have tried with every version of Dot Net installed together and individually. Any ideas on how to get this working again?
I’m sorry, I haven’t updated this app in a long time. It’s because I switched to SignalRGB and most of my time and energy is used to connect my devices to that. In stead of working on this prototype.
Is there more direct integration for ESP32 to SignalRGB or does it still use the WLED firmware on the ESP32?
There’s still the WLED integration and there are Teensy and Raspberry Pi Pico integrations. But I don’t think there’s a direct ESP32 integration.
