I’m trying to use the json API to activate individual LED’s. I only have the single segment that is active by default. I am using the json API, and providing a json file to the -d curl flag.
I have a 16x16 LED sheet attached to an ESP8266 module, for a total of 256 individual LED’s. The json files I have are addressing each led, per documentation HERE. I’m able to address up to LED 127 with no problem, but then receive {“error”:9} in the response.
Is there a limit to how many LED’s can be addressed at once? Is there a better way to have a map of LED’s that I can push at-will? The final goal is to basically have a ‘bitmap’ that I can have push to WLED from home automation.
Here is the file I’m using that gives the error. Removing LED 127 from the top will allow it to work:
"seg": {
"i": [
127, [255, 255, 255],
126, [255, 255, 255],
125, [255, 255, 255],
124, [255, 255, 255],
123, [255, 255, 255],
122, [255, 255, 255],
121, [255, 255, 255],
120, [255, 255, 255],
119, [255, 255, 255],
118, [255, 255, 255],
117, [255, 255, 255],
116, [255, 255, 255],
115, [255, 255, 255],
114, [255, 255, 255],
113, [255, 255, 255],
112, [255, 255, 255],
111, [255, 255, 255],
110, [255, 255, 255],
109, [255, 255, 255],
108, [255, 255, 255],
107, [255, 255, 255],
106, [255, 255, 255],
105, [255, 255, 255],
104, [255, 255, 255],
103, [255, 255, 255],
102, [255, 255, 255],
101, [255, 255, 255],
100, [255, 255, 255],
99, [255, 255, 255],
98, [255, 255, 255],
97, [255, 255, 255],
96, [255, 255, 255],
95, [255, 255, 255],
94, [255, 255, 255],
93, [255, 255, 255],
92, [255, 255, 255],
91, [255, 255, 255],
90, [255, 255, 255],
89, [255, 255, 255],
88, [255, 255, 255],
87, [255, 255, 255],
86, [255, 255, 255],
85, [255, 255, 255],
84, [255, 255, 255],
83, [255, 255, 255],
82, [255, 255, 255],
81, [255, 255, 255],
80, [255, 255, 255],
79, [255, 255, 255],
78, [255, 255, 255],
77, [255, 255, 255],
76, [255, 255, 255],
75, [255, 255, 255],
74, [255, 255, 255],
73, [255, 255, 255],
72, [255, 255, 255],
71, [255, 255, 255],
70, [255, 255, 255],
69, [255, 255, 255],
68, [255, 255, 255],
67, [255, 255, 255],
66, [255, 255, 255],
65, [255, 255, 255],
64, [255, 255, 255],
63, [255, 255, 255],
62, [255, 255, 255],
61, [255, 255, 255],
60, [255, 255, 255],
59, [255, 255, 255],
58, [255, 255, 255],
57, [255, 255, 255],
56, [255, 255, 255],
55, [255, 255, 255],
54, [255, 255, 255],
53, [255, 255, 255],
52, [255, 255, 255],
51, [255, 255, 255],
50, [255, 255, 255],
49, [255, 255, 255],
48, [255, 255, 255],
47, [255, 255, 255],
46, [255, 255, 255],
45, [255, 255, 255],
44, [255, 255, 255],
43, [255, 255, 255],
42, [255, 255, 255],
41, [255, 255, 255],
40, [255, 255, 255],
39, [255, 255, 255],
38, [255, 255, 255],
37, [255, 255, 255],
36, [255, 255, 255],
35, [255, 255, 255],
34, [255, 255, 255],
33, [255, 255, 255],
32, [255, 255, 255],
31, [255, 255, 255],
30, [255, 255, 255],
29, [255, 255, 255],
28, [255, 255, 255],
9, [255, 255, 255],
8, [255, 255, 255],
7, [255, 255, 255],
6, [255, 255, 255],
5, [255, 255, 255],
4, [255, 255, 255],
3, [255, 255, 255],
2, [255, 255, 255],
1, [255, 255, 255],
0, [255, 255, 255]
