Skipped LEDs flashing
I have set up 1153 LEDs divided into 4 strings, driven by 4 separate GPIOs. All seems to be working ok except that some of the strings have a few LEDs at the beginning that I don’t want to light up. I tried skipping them but instead of going dark, they flash, all at the same rate. The rate appears to track with the refresh rate as I change effects. All skipped LEDs flash on all strings. Some flash white, some other colors.
Using v.14.0-b4
Here is the configuration json:
{“rev”:[1,0],“vid”:2308110,“id”:{“mdns”:“wled-49861c”,“name”:“4_String”,“inv”:“Light”},“nw”:{“ins”:[{“ssid”:“Split_B”,“pskl”:9,“ip”:[0,0,0,0],“gw”:[0,0,0,0],“sn”:[255,255,255,0]}]},“ap”:{“ssid”:“WLED-AP”,“pskl”:8,“chan”:1,“hide”:0,“behav”:0,“ip”:[4,3,2,1]},“wifi”:{“sleep”:false},“hw”:{“led”:{“total”:1153,“maxpwr”:14000,“ledma”:12,“cct”:false,“cr”:false,“cb”:0,“fps”:42,“rgbwm”:255,“ld”:true,“ins”:[{“start”:0,“len”:313,“pin”:[2],“order”:0,“rev”:false,“skip”:0,“type”:22,“ref”:false,“rgbwm”:0,“freq”:0},{“start”:313,“len”:275,“pin”:[14],“order”:0,“rev”:false,“skip”:4,“type”:22,“ref”:false,“rgbwm”:0,“freq”:0},{“start”:588,“len”:345,“pin”:[1],“order”:0,“rev”:false,“skip”:8,“type”:22,“ref”:false,“rgbwm”:0,“freq”:0},{“start”:933,“len”:220,“pin”:[3],“order”:0,“rev”:false,“skip”:6,“type”:22,“ref”:false,“rgbwm”:0,“freq”:0}]},“com”:,“btn”:{“max”:4,“pull”:true,“ins”:[{“type”:2,“pin”:[0],“macros”:[0,0,0]},{“type”:0,“pin”:[-1],“macros”:[0,0,0]},{“type”:0,“pin”:[-1],“macros”:[0,0,0]},{“type”:0,“pin”:[-1],“macros”:[0,0,0]}],“tt”:32,“mqtt”:false},“ir”:{“pin”:-1,“type”:0,“sel”:true},“relay”:{“pin”:-1,“rev”:false},“baud”:1152,“if”:{“i2c-pin”:[-1,-1],“spi-pin”:[-1,-1,-1]}},“light”:{“scale-bri”:100,“pal-mode”:0,“aseg”:true,“gc”:{“bri”:1,“col”:2.8,“val”:2.8},“tr”:{“mode”:true,“dur”:7,“pal”:0,“rpc”:5},“nl”:{“mode”:1,“dur”:60,“tbri”:0,“macro”:0}},“def”:{“ps”:0,“on”:true,“bri”:128},“if”:{“sync”:{“port0”:21324,“port1”:65506,“recv”:{“bri”:true,“col”:true,“fx”:true,“grp”:1,“seg”:false,“sb”:false},“send”:{“dir”:false,“btn”:false,“va”:false,“hue”:true,“macro”:false,“grp”:1,“ret”:0}},“nodes”:{“list”:true,“bcast”:true},“live”:{“en”:true,“mso”:false,“port”:5568,“mc”:false,“dmx”:{“uni”:1,“seqskip”:false,“e131prio”:0,“addr”:1,“dss”:0,“mode”:4},“timeout”:25,“maxbri”:false,“no-gc”:true,“offset”:0},“va”:{“alexa”:false,“macros”:[0,0],“p”:0},“mqtt”:{“en”:false,“broker”:“”,“port”:1883,“user”:“”,“pskl”:0,“cid”:“WLED-49861c”,“rtn”:false,“topics”:{“device”:“wled/49861c”,“group”:“wled/all”}},“hue”:{“en”:false,“id”:1,“iv”:25,“recv”:{“on”:true,“bri”:true,“col”:true},“ip”:[192,168,1,0]},“ntp”:{“en”:false,“host”:“0.wled.pool.ntp.org”,“tz”:0,“offset”:0,“ampm”:false,“ln”:0,“lt”:0}},“remote”:{“remote_enabled”:false,“linked_remote”:“”},“ol”:{“clock”:0,“cntdwn”:false,“min”:0,“max”:29,“o12pix”:0,“o5m”:false,“osec”:false},“timers”:{“cntdwn”:{“goal”:[20,1,1,0,0,0],“macro”:0},“ins”:},“ota”:{“lock”:false,“lock-wifi”:false,“pskl”:7,“aota”:true},“um”:{}}
A known bug. Will be fixed in an upcoming release.
I can live with the extras being lit for now. Good to know it’s a bug and not something I am doing wrong.
