Hi. I was getting crazy, I spended many many hours trying all the possible and impossible things to solve a blinking issue, then i downgraded to v 0.13 and it stopped and started working.
Unfortunatly there’s no 2d matrix, but i solved it by other ways.
same issue happens with sk6812 rgbw, that blink rythmically, the ws2815 instead works, but with a little flickering always on top, unusefull for any production too.
Out of this, thanks a lot great man, wled is awesome.
video
https://drive.google.com/drive/folders/1aXfYyRP_drgWaKrFxLwGGpITnZOTWgKE?usp=sharing
What version of 14 were you using?
Did you OTA it? If you did I would reflash it with 14.b4 using a pc and not with OTA.
Did you try to flash it more than once? Sometimes things do not always flash correctly.
Strange, i tryied to open the gdrive link with another account and i see the contents. If you want i’ll put them somewhere else, sure.
To flash the esp i was using the web page only, but i did it many times with any differences. I was flashing the last all the time.
I’ll take a screenshot of the settingns you asked me asap
Try using this site and give 14.b4 a try and see if the flickering is still there: https://wled-install.github.io/
yooo super Jinx
you solved that!
may you please explain what have you done?
what are differences between wled 0.14.b4 of
https://install.wled.me/ versus https://wled-install.github.io/,
just because they are named the same.
I’ve never seen the website of your link before
works! thanks a lot
Not a clue. I just know that site has been working better than the other one. Are you sure you tried ‘b4’ from install.wled.me and that it wasn’t maybe ‘b1’ or ‘b3’?
