Smallest board (size)
So may seem dumb, but figured I’d ask here since this IS the WLED goto place.
Which board has the smallest Physical size (that’s readily available via internet purchase) that WLED can be installed and run on? Is it the Wemos mini?
It is probably the smallest unless you went with an esp12f basically the board mounted on the d1mini. It has not support circuits like usb to serial. Also don’t know if the d4 pin is broken out or if you need a custom compile. But that is the only smaller one I know of.
Wemos D1 mini (ESP8266) or ESP32 mini kit (ESP32)
Thanks folks.
I‘d say m5stack atom light is smaller and can be used. Not tested though.
