Hi Guys, my SP511e is still running. Unfortunately I need 280 LED instead 260 max. allowed in the sp511e.bin. How can I compile a relaese with out Alexa Blink and some other. But with a IR interface.
A hardware discription was in the New Controller thread
Thanks for the quick reply. If there an additional space needed between the -U and WLED…
I saw the wled.h file can I do the changes there?
Danke für die schnelle Antwort. Muss da nicht ein Leerzeichen hinter -U WLed…
Kann ich die Änderungen auch in der Datei wled.h vornehmen.
Gruss Roman
Once you have cloned WLED for your own needs, you are free to change any of the files as long as it adheres to the licensing (don’t change files by removing the licensing information - I think).
