Sunrise effect: How to properly end/reset effect?
Good Morning,
I have a issue with the sunrise effectf, as it looks like the effect uses the last state from the day before, meaning it turns on and is already in it´s final bright state.
Is there a way to gracefully turn off the effect, so it can restart the next day from the beginning?
I´m just using the effect with 5 Minutes duration and a width of 0, so it doesn´t get too bright, and the preset is called in the morning by Home Assistant, alongside other things:
{“on”:true,“bri”:128,“transition”:7,“mainseg”:0,“seg”:[{“id”:0,“start”:0,“stop”:96,“grp”:1,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“set”:0,“col”:[[0,0,0],[0,0,0],[0,0,0]],“fx”:104,“sx”:5,“ix”:0,“pal”:0,“c1”:128,“c2”:128,“c3”:16,“sel”:true,“rev”:false,“mi”:false,“o1”:false,“o2”:false,“o3”:false,“si”:0,“m12”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0}]}
You can create a playlist, start up with a black preset, thenn call the effect.
or maybe reset the timebase, try if it works if you add “tb”: 0 to the preset
