Sync question
Hello, I’ve 4 QuinLED DIG UNO with 4 WS2815 Strips (about 6 meters each) with WLED 15.0 installed.
The controllers are in the same wifi network, controlled by Unifi UDM PRO. Everithing is working except the Sync. All WLED instances sync settings are default , ports, groups, etc…
In the Node menu of each controller are listed the three other controllers.
There is something else to configure or check?
Thanks in advance for the support.
did you enable sync? i.e. the sync item at the top?
Yes there was a change in 15 , make sure you select “Send notifications on button press or IR” on the master and it will work
It works! thanks ALDIY for the suggestion. I was starting to thing about network udp limitation but it was just a button. Thanks again for the support :slight_smile:
