WLED version 13.1
I have seen the post here that says the state of the sync button can be saved into a preset along with the other settings.
However when I switch preset or set power up to use that preset the sync button remains off?
Am I missing something?
yudi83
#2
the sync its not working , i have same issue even i turn on sync tab on top . 2 segments always not same .
shitt…
@yudi83 Your issue is not the same as I describe.
For me sync works perfectly until I switch off the power. The preset does not load with sync turned on, even though that is how it was saved.
yudi83
#4
only some mode for example running mode
and not samo on for example fireworks.
