Timer question
I have an esp32 controller. I have been using it for 2 months and have used the timer to turn on and off a preset. I have now changed to a new preset and now this preset will not turn on at the set time. I have to turn it on manually , but it will turn off at the set time. Has this happened to anyone .
Are you picking of Time from an NTP server?
Post a shot of the time macros and your presets.
Are you sure your preset included the check box for ‘Use Current State’ when you created it?
Look at the Api for the preset see if it starts with “on”:true
Yes , ntp server. Time is correct.
Ver.14.3. API command “on” false. Should I change that to true.
Your pic shows "on’:false
Change it to True
That worked. Thank you
